Potterton Kingfisher flue being condemed by BG
15 Jul 2008
Berkshire
Get second opinion. ..
Thanks for the advice. I've done that and it looks as though my flue connection may be fixable ...phew..
[/quote]
Hi, I appear to have the same problem with a Potterton Kingfisher flue being condemed by BG. Were you able to get your flue fixed?
Start a new thread with more detail, e.g. exact model and G.C. number of appliance etc.
So what boiler do you actually have??
I have an Ideal Classic FF-2 boiler, with a Megaflo tank and Lifestyle LP522 timer. My problem is I can only get hot water when the central heating is on.
If I turn off the C/H on the timer on set the H/W to on, the boiler does not fire up. I have to set the C/H to on and the H/W to on, to get H/W. When C/H and H/W are set to 'on' on the timer, I have tried turning off all the room thermostats to trick the system. In this case the H/W does not get hot as the boiler does not fire up. As soon as I turn up a thermostat the boiler fires up and gives me C/H and H/W.
Any ideas or help would be aprreciated.
