Hello
I have a Potterton Kingfisher MF RSL60 boiler.
The problems seam to be with the thermostate as the boiler will keep running and not cut out when the water is too hot, resulting in the radiators becoming very hot (100*c).
Every now and again, the boiler will shut off and a relay type clicking sound can be heard which I think is the thermostate switching on and off about once a second and the fan speeds up and slows down.
This will continue for about 30 seconds and will end with the boiler firing up or staying off but if, during the clicking, the temperature control knob is moved up or down then the boiler will fire up.
I crudly tested the temperature control varible resistor with a multimeter and i appears ok with no dead spots.
I replaced the thermistor with a new one as they are cheap and I thought it was worth a try but it made no difference.
Any ideas?
Adrian
Any ideas?
Adrian
