my girlfriends boiler is a potterton netaheat 1016 wich is not working theres live coming to pcb board but nothing coming out fuse ok relay operating ne ideas
fans not runningsimon20569 said:my girlfriends boiler is a potterton netaheat 1016 wich is not working theres live coming to pcb board but nothing coming out fuse ok relay operating ne ideas
There's a connector with two red insulated wires from the PCB which go to the fan. Check there's 230vac between these pins on the PCB, then measure the resistance between these red wires, it should be less than 50 ohms, else you may have a duff fan or poor connections.simon20569 said:fans not running
Yup easy peasy to refit but how did you check that the case and seal was airtight?Well Ive had mine for over 20 years, the case is not that hard to refit tight and true.
