Hi everyone
I have an issue with the above make of boiler. Basically 2 symptoms
1. when turning on the hot water in the bathroom it is only luke warm. Can be made scolding hot if the tap not on full force.
2. When tap in bathroom is on full force the rads start to heat up.
I have done a bit of research and it points to either the Plate HE or the diverter valve or both.
Questions! If the Plate HE is blocked is this easy to remove and clear?
Second, if the diverter valve is faulty will the whole casing need to be replaced or just the diaphragms inside?
Would it be the DHW valve or the CH valve which is faulty?
Dante
Dante
