Hi, I have spent last few hours reading to try and find a solution but to no avail.
Over last few days problems with my hot water have occurred.
When hot water did not worked I increased the pressure by .5 bar then it would work again. This went fine until I got to around 2.5 bar where I didn't want to increase anymore.
Also I found that if I turned the tap on full or another tap as well hot water would come but now not anymore.
When I turn the hot tap on the switch goes and the boiler starts but there is no ignition. The next thing that happens is I get a warning light which indicates low pressure or the pump fault.
The central heating used to still work well, even when the hot water had stopped working. Now though when I try the central heating the ignition light starts, temperature goes up but at around 70 degrees it now gives the same error as the hot water(low pressure or pump fault)
The pre heating function still works fine.
This all happened 3 weeks ago but then it seemed to fix itself.
Any ideas would be much appreciated?
