Hi I have a few problems with this boiler.
1. The pressure is increasing over 3 bar and water is coming out of the PRV. I assume this is down the the expansion vessel not having enough pressure in it. The thing is I had the expansion vessel replaced about a year ago - do they loose their pressure regularly? I will re-charge with foot pump and see if that sorts it.
2. I have had one instance of the CH being on put the rads not getting warm. I checked the boiler and the HW light on the boiler was flashing but none of the taps were open. I opened and closed a tap and went back to check the boiler - the HW light had gone out and the CH had come on. Is this the symptoms of a sticking 3 way valve? If so do you have to replace the whole valve or just certain parts? How can I check that the valve is operating correctly? Would it be worth flushing the system with anything?
