I noticed my boiler would keep attempting to start, i.e. the fan would start, but then it would cut out. I checked the operation of the air pressure switch and it seemed to be suspect. I've replaced this but the problem still exists. I've found that if you operate the pressure switch by blowing in the connecting pipes when the boiler is trying to start, you can make it fire up. I have checked all the connecting pipes for blockages or leaks and the little timing choke in the clear pipe is not blocked. If the boiler switches on and off on its own thermostat it can start without a problem. But, if the main room thermostat switches the boiler off, then switches it on again, the boiler keeps cycling with the fan starting and stopping, but he gas never switches on. I have checked the PCB for dry joints and can't see anything obvious, however I'm beginning to think there may be a problem with a sticking relay in the control unit, after I got the boiler to start by tapping the control unit while it was in the 'fan cycling' state. Has anyone got any ideas on what I should try next?
