    Dismiss Notice
Potterton Profile 60e not firing.
Discussion in 'Plumbing and Central Heating' started by Thecasementkid, 23 Feb 2021.
  1. Thecasementkid
    Thecasementkid
    12 Nov 2005
    24
    Thanks Received:
    London
    Country:
    Hello,
    Before I call the boiler repair company, can you give me a heads up on what potential issues may be at fault.
    Potterton 60e boiler that in the last couple of years has had a new fan and circuit board.
    Working fine up to last night, then noticed in the early hours the house was cold.
    Checked the thermostat and heating was supposed to be on. Gas cooker working ok so not a supply issue.
    Checked boiler and I could hear the fan turning but the boiler was dead. It wasn’t attempting to light the pilot as it does before igniting the main boiler, just fan hear the fan running and nothing else.
    When the circuit board was replaced last year, you could hear clicking and it attempting to light.
    I was told a relay had burnt out, but this time there’s nothing.
    Any pointers appreciated.
  2. Sponsored Links
  3. Mottie
    Mottie
    27 Feb 2017
    18,846
    Thanks Received:
    1,886
    Essexshire
    Country:
    Including the original, I got through four circuit boards on my Profile 60e during my ownership. Fairly common I think. Was it a new OE one you used or a pattern/refurbed one? If less than a year, is it guaranteed?
  4. ianmcd
    ianmcd
    15 Aug 2010
    23,446
    Thanks Received:
    9,666
    Lanarkshire
    Country:
    have you tried the over/heat reset button under the boiler ?
  5. TimboTwo
    TimboTwo
    30 Jan 2021
    156
    Thanks Received:
    28
    Country:
    Fan pressure switch.
  6. Mottie
    Mottie
    27 Feb 2017
    18,846
    Thanks Received:
    1,886
    Essexshire
    Country:
    I had that pop a few times on mine too. Only when I had the boiler temperature on Max setting though. It did that from new. Perhaps the boiler was too big for my system?
  7. Sponsored Links
  8. ianmcd
    ianmcd
    15 Aug 2010
    23,446
    Thanks Received:
    9,666
    Lanarkshire
    Country:
    when your boiler was installed it should have been range rated , it can be rated between 50,000BTU and 60,000 BTU it comes set at max, so if doing it from new was pobably set up wrong, they do tend to activate as they get on though, but good boilers very simple and not a lot to go wrong
    • Thanks Thanks x 1
  9. Thecasementkid
    Thecasementkid
    12 Nov 2005
    24
    Thanks Received:
    London
    Country:
    Judging by the price paid, it was a pattern. The proper boards are a fortune.
  10. Thecasementkid
    Thecasementkid
    12 Nov 2005
    24
    Thanks Received:
    London
    Country:
    Thanks for the suggestion but the button is up. The fan runs as normal, you can see the ignition sparking but the boiler won’t ignite. Just happened all of a sudden.
  11. Thecasementkid
    Thecasementkid
    12 Nov 2005
    24
    Thanks Received:
    London
    Country:
    Unfortunately not. Tried a new one but no difference.
  12. Mottie
    Mottie
    27 Feb 2017
    18,846
    Thanks Received:
    1,886
    Essexshire
    Country:
    My last one was an original one - I needed it in a hurry and bought it from a shop two days before Christmas. I think I paid around the £200 mark. A year or so later when I had the boiler changed, I put it on ebay and got over £50 for it!
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
