Potterton Profile Boiler
31 Dec 2003
I discounted a bathroom sink and radiator and since then the boiler ignites but goes out after about 20 seconds - I only have the Hot water system enabled. I have a feeling it may be to do with an air lock and pressure in the pipe, but how do I clear the air.
The other problem is that the reset switch appear to get stuck and will not release to allow me to reset and ignite the boiler.
Any advice will be very much appreciated especially as it's bank hoilday tomorrow!
Look for a bleed valve by your HW cylinder.
I don't think the discount you gave on the bathroom sink will be contributory...
Thank you. The problem did appear to be pressures, once alleviated the boiler continues to run.
One other slight problem which could well be connected is that although the central heating is off, the CH pump continues to run. It is also getting very hot. I managed to physically turn off using the speed switch. But turning the boiler off and then starting the pump it still constantly runs.
Any ideas??
It WILL run if the boiler is still hot , there's an "overrun " thermostat.
But they do go faulty , in which case they can hold the boiler on continuously, or just the pump. Manual is here http://www.partsarena.com/baxi/
