Any advice please?
About 3 weeks ago, I noticed that my Potterton Promax boiler was switching off after about an hour - rads going cold. The only way to fire back up was on the reset on the front of the boiler at which point it would re-fire and then follow the same pattern.
Over the space of a couple of weeks, the time before shutting off became noticeably shorter.
My home insurance emergency cover sent out Engineer 1 (an odd-job man) who diagnosed a that the thermostat in the hall needed changing. this was done - no change. He concluded that the boiler was not economically worth repairing !!!!!! (Around 8 years old)
Home Emergency team sent out Engineer 2 ( a builder who helps out his mates heating firm from time to time). he diagnosed main PCB. This was changed (however he also said that the Freezing stat was faulty as well as a possible pump ................?????!!!!)
Following PCB change - still no change!!!!!!!
Heating Engineer 3 (genuinely nicer bloke) believes it's a sensor on the main pipe out of the boiler...... He checked the resistance and believes it's that.......
I have had no HEAT or HOT WATER for 8 DAYS!!!!
It's -1 outside and feels like that in here and my insurance company states that I'm almost at the maximum claim limit.
So if engineer 3 fails ......... And it's now just over a week till Xmas and I have already been without H&W since then......
Any thoughts about the problem ????? (Other than engineers who can't identify it)
