*disclaimer* before anyone mentions it, a Potterton engineer will be getting called out.
So the problem;
Occasionally the boiler was locking out, with the fault code indicating overheat. Takes around 10-15 minutes to reset the boiler.
It usually only happens once, & after reset, works fine for the rest of the night.
I noticed it was ok when DHW only was on, however, 10 minutes after switching on CH it would trip.
Had a look at the motorised valves, & the CH one seemed to be sticking slightly. Great I thought, easy fix.
I then drained & flushed the system, replaced both motorised valves (Drayton 2 port), cleaned out the Magnaclean (which didn't have much in it) filled up with Fernox inhibitor, and tried it.
Worked fine for a bit, then to my great disappointment, it tripped out on overheat, but only when CH is on. DHW is fine.
So, when funds permit, I'll be biting the bullet & getting it looked at, however, in the meantime any thoughts?
I initially thought it might be the heat exchanger blocked, but it's only when the roads are on...
Thanks in advance..
So the problem;
Thanks in advance..
