Potterton PRT2 Room thermostat.
29 Dec 2009
Sussex
Hi
My Potterton PRT2 room thermostat when set to control a room temperature of 20 degrees actually controls the temperature to 23 degrees, is there anyway of adjusting the temperature on the scale of the thermostat to accurately reflect the temperature of the room?
Best regards
HH
BTTT.
Can anyone offer any information on if this is possible??
Thanks...
HH
Im not sure if you can do that. Do the reached/below lights work correctly? If not it doesn't have a neutral.
Pull off the dial. The control dial has a phillips screw which you can slacken off. If its not got a locator pin you might be able to adjust it to suit your situation.
They are a good stat and much better than the bi-metallic versions.
Hi
Thanks for your reply. Yes the below and reached lights do work correctly.
I'll try and get the control dial off and let you know.
HH
