Hi There,
I have read several messages on this forum relating to a similar problem that I have but have yet to find a definitive answer.
I inherited a Puma 100e after moving into my property a couple of years ago - it was installed in 2000.
I have the following problems:
1) After using hot water, the flame light does not go out and the boiler overheats and "blows". On some (not all) occasions this causes a "Lockout". This happens frequently AFTER using hot water through a shower or tap (normally for at least 20-30 seconds but can be longer).
2) My central heating does not work properly at all. The heating upstairs comes on luke warm after 90mins but the ground floor radiators are freezing. The radiators were balanced not long ago.
I can think of no particular events that have caused this to happen. I can tell you three things that have been changed while this problem has been occurring:
1) The descaler burst. (i think thats what its called - purplish rectangular "thing" that connects to pipes and is supposed to descale the water?). This has not been replaced - a pipe was simply used to connect everything back up.
2) The electronic timer was not working for the heating. This was replaced by pottertons own mechanical timer, which seems to work.
3) The valves on virtually all the radiators were changed as they were quite old.
The radiators have been bled.
I have noticed that if you put a cold water tap on immediately after using the hot water then the boiler is less likely to blow.
Can anybody provide a list of solutions?????
Thanks in advance - i'm ready to try anything as i need the heating before the winter really kicks in!
xdee
MOD
please see item 17
post has been split
xdee
MOD
please see item 17
post has been split
