potterton puma 80 boiler issues
31 Oct 2008
London
hi
Not sure if it is related but about a month ago the pilot light kept going out when the central heating turned off.after a few days this prob went away.
Now a few days ago there is a loud whirring sound whenever it is firing.sometimes it is very loud. Last night the pressure dropped and I had to top it up this morning. When I turn off the thermostat and it stops firing for a few seconds the whirring slows and almost turns to a scraping before stopping.
Any ideas?
Fan?
If it's a P (permanent Pilot) version the fan should run slowly if the boiler's off. If it stops, the boiler could well overheat and cut out.
many thanks for the reply
do you know how i tell if it is a P version?
assuming it is the fan is it an easy or hard thing to replace? could i do it myself? i am reasonably handy but have no real plumbing experiance.
If you mean it has a permanent flame in it, that's the pilot! The other type has electronic ignition.
No, I wouldn't recommend you try changing the fan yourself. There are several things which you could do wrong without realising.
well the loud whining seemed to have been dying down.....however this morning the bloiler would not fire at all despite the pilot light being on and the pressure seeming ok.
