Ive had this issue for nearly a year now. I have replaced the flow switch (just the micro-switch)before as once the hot water tap was switched off, the led on the main board never went out and the boiler over-boiled, rattled and switched off every time.
I have adjusted the switch but if I adjust it slightly more it over-boils again. If I adjust it the other way, it fails to provide hot water.
As I mentioned, Ive replaced the switch (was an easy job) but do you think it needs the main flow switch replacing? Would that provide constant hot water at a constant temperature?
If so, is it an easy job?
many thanks,
Tc
many thanks,
Tc
