Dear All
I posted a similar post while back but am looking for some fresh advice.
I have the boiler model mentioned in the subject feeding a mixer tape shower (no thermostatic control). If I have a shower in the evening the shower is perfect; lovely constant flow & temperature with the ability to adjust as required. If I try to have a shower in the morning however the temperature goes from hot to cold constantly as does the water flow; as the boiler cycles from ignited to not. There is no differences in the house at these different times so I can only think that maybe water pressure to the house is causing this as maybe in the morning the water flow is not sufficient enough to take the heat from the boiler. Am I barking up the right tree & if so is this something that can be rectified or tweaked?
