Potterton supreme 80 problem
6 Apr 2011
Glasgow
Fan comes on and boiler lights flow pipe roasting return pipe cold then boiler shuts down pump not coming on got pump changed today still same problem anyone no problem.
Thanks in advance
Was told in another forum that it was definitely the pump that was the problem obviously pump is ok
that person is a tw@t for saying its a definite being behind a computer , unless of course it depends on the details you've given him ;) . keep changing parts until its fixed, dont worry you'll get there :cry::sneaky:
That's a good idea.
By changing expensive parts in turn you will eventually end up curing the fault.
However, it could be cheaper to engage a boiler engineer to correctly diagnose the fault first.
I will echo Tony's Responce. Good idea. Start changing parts. You will be able to fix your boiler. (y)
New pcb fitted today still same problem ,fan comes on boiler fires up flow pipe roasting boiler shuts down as pump not coming on any ideas what problem is?
It is obviously something else!
But by changing everything in turn you will eventually end up with it working again.
yes fitted new pcb.
this boiler doing my nut in
just think you could of just put multimeter on pump to see if getting 240v instead of getting a PCB :cry::) , where are you buying or acquiring spares ?
if you want help you need to know how to use a multimeter , can you ???????
if you can't stop messing with the boiler and it will probably be cheaper to find a repair engineer ;)
