- Joined
- 30 May 2004
- Messages
- 90
- Reaction score
- 0
- Country
The manufacturers of my new heat exchanger (fully pumped, indirect open-vented system) recommend setting my Potterton Suprima 50 to MAX, for optimum performance.
This seems to be fine but I am convinced the correctly-wired pump does not overrun. On rare occasions the boiler will kettle (bang) for a minute & also cut out.
I have read here about some basic points to check, such as cleaning electrical connections to the PCB &, on a more advance level checking the overheat thermostat/temperature sensor.
Is Servicesol good for the cleaning & how would you check the overheat thermostat/temperature sensor? I assume I would only need to look at those items dealing with the pump operation.
