Hello
I have had a new Potterton Surpima HE boiler installed under a year ago. We have a problem that has been happening since installation really.
When heating is on the boiler goes to lockout, often after having the boiler running for about 1/2 hour. The boiler manual fault light says it is a circulation problem.
My installer has tried everything, all air is out of the system, the bypass has been set properley, and he says the pump (which was already installed: Grundfos 15/50) should be OK as the fault does not happen immediately and only afte the boiler has been running for a period of time.
We have a 4 bed-house, an open vented system with 2 x 2 port motorised valves, a tank in the loft and a hot water cylinder in the airing cupboard.
What can be the problem please? Any ideas? My installer has now said it may be the board at fault, but the board was brnad new (part of the new boiler)?
Any ideas would be greatful, if I could try anything or even suggest anyything?
I suggested sludge may be trapped in the boiler, but he said it isn't that, and hot water seems to be fine anyway and that uses the same heat excahnger.
