Power failure not tripping an RCBO
Don't some styles of RCBO have a "tripped" position which is not the same as the "Off" position and need to be pushed to the "Off" position as part of the reset sequence.
A couple of examples have been mentioned already, but it seems relatively rare on U.K. brands, unlike here in the States where many makes of breaker (regular and GFCI) have a "center trip" position and you have to push the operating handle all the way back to off to "catch" the mechanism in order to switch on again.
The "D" inside a square logo comes from Square D originally being called the Detroit Fuse & Manufacturing Co. Apparently the symbol became so well recognized that they decided to adopt the "Square D" name instead.
As far as residential applications are concerned, the two common Square D ranges are the cheaper HomeLine units and the QO range, which has been in production for decades and long been highly regarded. Unfortunately, Square D did move production of boards from the U.S. to Mexico a few years ago and cheapened the construction (mounting rails now being plastic instead of steel, etc.).
On the central-position trip issue, American Square D breakers have it, like many brands here. But Square D also introduced the "Visi-Trip" indicator back in the 1960's, with tripped breakers showing an orange indicator in a small window. Several other brands have followed suit more recently.
