Power meter
24 Sep 2005
Trying to max info from a Maplin Power Meter.
Surface mounted radial circuit.
Connections bright and tight.
Length 5.3 M within a centimeter or so.
Appliance rated 2700W at 240V.
Measured at the socket supplied.
No load 242.3 V
Load applied 10.9 A : 239.3 V
242.3 - 239.3 = 3.0 V
3.0 V / 10.9 A = 0.275 Ohms ..
Which resistances in total combine to produce the 0.275 value?
No load 242.3 V
Is the voltage INTO the meter constant at 242.3 V or does that also drop on load.
The voltage drop will be spread all along the conductor string from the network transformer to the pins in the socket.
No load 242.3 V
Cheers B,
The meter reads volts (off load) 242.3V
On load (10.9 A) the meter reads 239.3V.
So I am not just reading the resistance of the cable from DCU?
:oops: deleted silly line.
Does the appliance plug top and lead etc have an effect?
Cheers. E
