I have a power-shower that works very well. Except, when I switch on the water, nothing comes out of the shower and the pump doesn't make a sound. I then have to lift the shower head off its hook and shakeit around for a moment; whereupon suddenly the pump kicks in and the shower works like a dream.
If I turn the shower off, then immediately back on again, it works fine. If, however, I leave it off for 30 seconds or more, I then have to go through this routine once more.
I presume that water is draining out of the shower head, and an air lock is forming somewhere between the wall outlet and the head: wiggling the shower head moves the bubbles and water can pass? Is this correct? If so, what can I do to prevent it?
There is a non-return valve inside the wall-outlet, which I presume is working fine, but maybe this is another possible cause?
Many thanks....
Potemkin
Many thanks....
Potemkin
