power shower / boiler info
21 Nov 2009
Leeds
hi all
will most combis accept a power shower?
if not which ones do?
will a duo-tec 33?
cheers
gasgirl x x x
No you cant use a power shower on a combi you need a standard thermostatic mixer shower
If you have a combi, the hot water is mains fed and therefore likely to have goodish pressure. Any decent combi will give at least 24kW - over twice the output of any electric shower. A power shower has a pump, and many give a ridiculously high flow rate.
Stick with the combi and compatible mixer.
