Had a Mira Excel fitted new with a motor in the boiling cupboard, pretty standard set up with hot water from the tank and I guess cold from the loft.
Shower was working great for the first few months then abruptly stopped.
Plumber says although he supplied the parts its nothing to do with him now, I have to talk direct to Mira and/or the company that manufactured the power motor bit.
When I turn the temperature up to max in the shower the motor kicks in temporarily giving scalding water until it cuts out after 60 seconds. On coldest feed only no water comes out and the motor does not kick in....
The motor company say it must be a water feed problem with the shower and there is no fault with the motor as even with it switched off water should come through the shower?!(is that correct?...a power shower should still work with the motor switched off?).
The catch 22 situation I am in is that Mira engineer comes out and says the shower is fine and the problem is with the pump...and vice versa...thus I get charged by them both with the original plumber washing his hands of the whole situation.
Grrrr!!!!...i just want to have a shower and my wife is killing me!
Any advice gratefully recieved!
