I've had some helpful advice from someone here before, I'm hoping to get some more if possible.
1. I can't find any filters, I've unscrewed all four hoses and have only found on the outlet side - a black plastic flap sitting in the pump.
2. I've established that it doesn't appear to be the Reed Valves - water is coming out of the tap and I can hear the switch click. I've also bridged S1/S1 - the two wires for the Reed Switch and hear the click but the motor still doesn't turn on.
Point 2 also points to the motor I think since its happening for both hot and cold at the same time - indicating the motor being the common denominator?
Is there anything I can check to confirm if the motor is starting to fail? Join a few wires up etc icon_biggrin.gif
