Hi All,
I am looking for some advice with an issue that we currently have.
We originally had a Mira Power shower when we moved into the house, the shower is connteced to the mains via an RCD spur on the landing. No isolation switch was present. Anyway about 6 months ago the RCD started to trip, sometimes during a shower and sometimes when the shower was not in use.
Recently its been so bad that I bought a new Mira Power shower (same footprint, same connections etc). I fitted it yesterday and replaced all existing wiring with 2.5mm2 cable (the manual said at least 1.5mm2 was needed). I put in a new wire to a ceiling mounted isolation switch too as this was missing on the original shower.
Checked all connections, checked for leaks all ok. Wired up RCD last night and flicked the power back on. Everyting worked fine. However I woke up this morning and found the RCD had tripped during the night despite the shower being isolated.
Had a shower this morning no problem, Just checked and again the RCD has tripped during the day (again the shower is isolated).
So my thoughts are now turning to the RCD itself being faulty? its tripped so many times this past 6 months that perhaps its now past its best? I coudl check all wiring again but I only did tht yesterday and am pretty sure its all ok.
The only think I have not done in accordance with the Mira instructions is to fit a double pole isolator with 3A fuse. I could not find an isolator with a 3A fuse whereever I looked! so am relying on the fuse in the RCD doing its job.
Anyone got any advice before I call in an Electrician to do some resistance testing?
