power shower?
27 Apr 2003
I am looking to install a thermostatic mixer shower in a ground floor room about 3 metres from the hot water tank. Do I need to fit an external pump to achieve a good pressure or will the fact that it is on the ground floor give me adequate pressure. The cold water tank is in the attic. Would I also be able to break into existing hot/cold pipework or would I need to run seperate feeds
How high is the cold water storage tank in the attic to the ground floor for your shower? and when you say hot water tank I take it you mean water cylinder.
The height is approx 3 metres and Yes I mean hot water cylinder
The height is approx 3 metres from cold water tank to shower head and yes I mean hot water cylinder when referring to hot tank.
You should be okay,the cold feed should come from the cold storage tank and the hot feed from the water cylinder for equal pressure.If you can, try and use 22m pipe as much as possible from the feed to the shower mixer for better flow/pressure.I have put in a separate cold feed from my cold storage tank (using tank connecter or T-piece) for safety,so if anyone turn on the taps you might find a quick blast of hot water into your shower.And finally why not put in a shower pump anyway,you won't regret it !
