Hi all,
I wonder if I could ask your advice, although I appreciate that my question may have been asked before.
I'm in the process of having a garden office/workshop built and I need to determine the size of the cable that will be required to provide power. I will be hiring a qualified electrician to terminate, fit the internal wiring and sign-off, however I'm not ready for that yet. I would like to get services (i.e. power, data water) to the location before the building phase starts.
The run from the house is approximately 35m, which consists of 20m underground, 8m clipped to external brick and the remaining distance would be indoor, clipped to brick. The likely load would not be expected to exceed 10kw, i.e. there will be no large loads such as motors or heaters. The house is serviced by a TNS supply, which I understand means that I can extend the earth to the new building using 3 core SWA without the need to mess about with providing local earth via ground rods. However to meet regs, the SWA earth must be 10mm2. The building will be made from brick, and the incoming water supply pipe will be MDPE, so no bonding required for this.From my calculations, 10mm2 would be an ample size to cater for the load.
So, before I purchase a 50m reel of 3core 10mm2 SWA, would someone be able to confirm that my thinking is sound and I have missed anything?
Many thanks in advance,
Matt.
Matt.
