Power to shed
15 Sep 2005
Would like to run SWA 22 MTRS from house CU to a new shed CU which will have one 6amp MCB for a light and one 16amp MCB for 3 sockets.
Can someone please confirm the SWA size and the MCB for the house consumer unit. A reference to the regs would also be great.
To make the house cu connection easier, is it ok to connect the SWA to a junc box then use T & E for the consumer unit connection.
If so, what size should the T & E be for connection to the house MCB.
Many thanks.
Do a search here for shed garage outside outbuilding outhouse - loadsa info.
http://www.tlc-direct.co.uk/Technical/Charts/VoltageDrop.html
http://www.diynot.com/forums/viewtopic.php?p=81696#81696
http://www.opsi.gov.uk/si/si2004/20043210.htm
Adaptable box, yes.
Yes
Same or larger than the SWA.
