My built in programmer/timer stop working. Boiler only works when switch kept to continuous hot water but this option did not provide me with heating. Looking at the wiring diagram I found a solution to by-pass the programmer/timer. I would like your views on this. My solution is on the wiring board connect port 24 (power from always hot water on switch) with port 18 (power to the thermostat). It is my understanding that this will get heating always on but always controlled by my thermostat as long as the switch is kept to hot water continuously. Your views on this would be much appreciated. I got it working and I have not found any issues yet. Note: I have safely disconnected the original wire to the port 18 from the programmer just in case.
