H
Hot&Cold
is the auto air vent open and functioning ?I'm hearing lots of bubbling water sounds when I call for central heating and the pumps starts.
was there any air charge in the 18l expansion vessel ?so I had to pump air back in the vessel again
The pump is now moving water and air around,lots of air as you had it part drained.It will gradually settle down keep bleeding the rads and the auto air vent will clear air from the top of the boiler.There is a ton of gurgling noises coming from the boiler, pipework and rads,
Top up water pressure at any time.When refilling the system do I need to let the boiler cool before introducing cold water to build the pressure back up?
The pump looks like the original powermax badged pump.usually single speed pump but if it has a speed selector ensure its on max speed.
The pump may be turning but we dont know how much water its shifting
