Onetap wrote
Calorfier.
The term calorfier generally refers to a type of INDIRECT CYLINDER heated by steam or high temperature hot water used mostly for non-domestic purposes,but see also STEAM HEATED CALORFIER.
Would you believe it, this was in my Treolar Encyclopaedia.
The store cooling down after a hot tap being opened will not drop the pressure to zero.
It might well be but the OP has already stated...
Then Onetap wrote
Which one. The one the OP has replaced or another one perhaps.
You still have not explained why the primary side is not being topped up again by mains water pressure.
Or perhaps the OP will explain what IS happening before you get worked up again and resort to your crystall ball .
Well, it's a hot water storage cylinder and not a plate heat exchanger. The word isn't much used in respect of domestic systems, so you wouldn't have known what it means.
Calorfier.
It happens when the hot tap is run, which would cool the store down.
It might well be that the expansion vessel has failed and there's no air in it.
Charge in the expansion was 0.7bar
Then Onetap wrote
I still think it's probably a failed heat exchanger.
