Pre cast door cill
5 Jul 2011
Kent
My architect has specified a precast concrete door cill with a weatherstop to go under the front door.
We had some custom precast stone cills put under the windows, but he says this would be a more off the shelf item, since you won't see it being under the door.
I'm really struggling to find a supplier in london when I search on google. Does anyone know what I should be looking for. I keep coming up with the same specialty custom precast stone makers. Which of course will be expensive.
I just want something off the shelf. Cross section will be about 50 x 80mm
Little update to my research if this helps anyone.
Looks like we could use:
Precast stone or concrete
Yorkstone
Blue Staffordshire Class A solid engineering bricks
The terms I should be using would be "Threshold", "slab", or "lintel"
General builders merchants occasionally stock the blue engineering bricks but not the others
The stone or cast products are very often custom made, and whilst they were used extensively in thresholds for old victorian buildings, it seems it is uncommon now.
I have found a few suppliers, mainly of reclaimed stone in kent
The precast stone will be expensive, and there are only a couple of suppliers down south
The precast concrete tends to come from the major concrete suppliers who have sub divisions for precast. It will be a stock item, but often tends to be a sloping sill, whereas I wanted a rectangular one.
Unless you are willing to collect, the delivery cost will be huge.
Best item for off the shelf, will be the engineering blues.
Hope that helps someone
