- Joined
- 13 Sep 2015
- Messages
- 324
- Reaction score
- 180
- Country
We would like to install some bifold doors, with a cast Bath/Ham stone header/lintel for the external face of the opening to match the rest of the house.
We have had structural calculations done. The structural engineer has specified the steels to carry the entire load but has suggested we try to find a cast stone header/lintel that can also carry some load in a 'belt and braces' way.
I can find plenty of companies that can make the header, all of which will reinforce with steel rebar to prevent it from cracking. However, they generally specify their headers as decorative with no defined load bearing capacity.
The only company I can find that gives any form of structural guarantee is Forticrete, who specify 4.7kN/m for their off-the-shelf parts. However, they're not answering my calls or emails - I guess they're trade only?
We can fall back to getting a non-bearing lintel (which is within the structural design), but does anyone know of any other company that can cast a stone lintel/window header with a specified load bearing capacity? If it helps, we're in the Bristol region and the span of the opening will be 2700mm, give or take. So, adding 150mm bearings we're looking at 3m in all.
Many thanks
James
Many thanks
James
