Premier Elite
10 Oct 2021
I've recently fitted a Texecom Premier wireless elite and had a local engineer round to commission it.
I've since tried adding some proximity tags I've tried everything and still can't get to Add Tag on the keypad, am I just being a numpty?
I've diligently followed the book instruction and various U tube videos but got nowhere
Following the book instruction the screen reads, Premier progamming for 24, 48, 88, 168 & 640. but it seems mine is 64 and underneath this number is: SW . V5 . 05 . l51.
Would appreciate any help,
Thanks.
Pete.
Master code ————
Menu
User menu
Yes
Scroll down
Set up users ….
Add tags from this menu
Thanks, I tried that but when it got to set up user I tapped yes and it asked for user code, what does that mean?
I tried entering master code again but it didn't like that!
You can add a code if required to each user or just press yes to carry on with setting up user , until it says add tag or import ( import if it’s used on another system allready ) you you need to check all the options in between
