Prep advice for wallpapering a newly skimmed ceiling
31 Oct 2011
West Midlands
Recently had our artexed ceiling skimmed over. (just over a week ago).
We would like to paper the ceiling but am not sure what preparation to do.
I see lots of advice for people wanting to paint new plaster but not wallpaper.
Should I mist coat with matt emulsion?
Size with wallpaper paste?
Use watered down PVA?
Thanks in advance
If you’ve gone to the trouble & expense of having it plastered why on earth do you want to stick paper over it :confused: , is it a poor plastering job?
You need to leave it 10 - 14 days before doing anything, longer if the Artex pattern was a heavy one as the plaster will be thicker. Sizing is probably best but the decs will confirm; whatever you do don't put PVA on it, it'll cause you all sorts of grief!
Thanks for the advice both.
TBH, we hate artex, but I must admit, the embossed wallpaper my missus liked the look of looked similar to the classic artex pattern. :confused:
The artex was in good condition and the plastering is very good.
On the other hand, I kind of feel that looking up at a smooth painted ceiling sounds a bit cold and boring.
What if we did paint the ceiling, then decided to wallpaper after all???
I have another problem now though that your comment about PVA gave me.
We had one wall skimmed over as well at the same time.
I put a 5:1 watered down PVA on it when it looked dry the other day. :oops:
No ill effects as yet.
I think she wants the wall painted.
Can I, should I, do anything before I paint that wall???
You should first using warm water and a broad edged scraper remove the PVA, then when dry seal with a thinned oil based undercoat. With regard to the ceiling if you are considering painting it at a later date first apply a mist coat.
Dec
You should first using warm water and a broad edged scraper remove the PVA, then when dry seal with a thinned oil based undercoat. With regard to the ceiling if you are considering painting it at a later date first apply a mist coat prior to the size.
Dec
Current fashion is for clean lines & coving free, square ceilings; textured finishes Artex or paper are definitely out!
That wouldn’t be a problem; mist coat the ceiling first using ordinary matt white emulsion (cheap own brand will do), this 25-30% & apply 2/3 coats in quick succession. Leave to dry overnight before applying your chosen finish coats.
Oh dear, you have just made one hell of a mistake; PVA & paint do not mix & you won’t be able to paint over it successfully, the paint won’t stick or cover & will look awful. You need to remove it all or go over with a specialist primer.
Some light reading for you;
//www.diynot.com/forums/viewtopic.php?p=855153#855153
//www.diynot.com/forums/viewtopic.php?p=468227#468227
//www.diynot.com/forums/viewtopic.php?p=1488592#1488592
Dec
Ok DEC thanks, what would you recommend for the thinned oil based undercoat?
Re the ceiling: - Its not so much a case of painting at a later date, but rather the possibility of painting first, then she don't like it and decides that she still wants it papered :confused:
