Hi - have been doing some bathroom renovations. Will soon, I hope, be ready for painting the wall I had to strip back to studs for some plumbing work.
All the walls in the (old) property have been insulated and drylined (no skim coat) when it was converted. So I'm going to do the same for my renovated wall. I've not done this before, so hey ho, but when it comes to painting, should I do anything to the Gyproc panel before painting? What about the joint filler?
Is this a case of using a mist coat(s?), or should I be using some kind of primer? Primer (if required) on the whole wall, or just the joint filler? I'm hoping I can just mist coat it, but if that is the path to doom, I'm happy to prime (or do whatever else is necessary).
Thanks,
Simon
Thanks,
Simon
