Hi, I am trying my hand at plastering and have a few questions about preparing for skimming the walls.
I have had a rewire and removed some loose plaster so have some patches back to brickwork, some cutting in with plastic conduit etc and some exposed copper pipework to cover prior to beginning skimming the walls. The bricks are oldschool & very porous.
What I am not sure about though is
1. Should I wire brush the brickwork or similar to remove any dust, old lime plaster etc and try to get a bit of a mechanical key or am I just wasting time?
2. I understand I should wet the brickwork a lot before bonding/hardwall to slow suction but should I also be putting on a PVA mix to try and control this too?
3. On the conduit would it be a good idea to do something like Roughcasters solution for Gloss paint, like neat PVA and bonding coat slurry to give the bonding coat something on the conduit to stick to? Or should I just rough it up with sandpaper, or 3 to 1 PVA, or not bother?
4. Existing plaster work is at least an inch deep in places, I seem to find different points of view on whether I should be using drywall or bonding.
Should I be doing something like drywall scratch, bonding coat, skim?
5. Been told plaster will corrode copper pipe work, is it ok to just cover it with duck tape as someone suggested?
Thanks in advance!
Thanks in advance!
