    Dismiss Notice
Preparing a concrete & floorboards space for Tiling
Discussion in 'Tiling' started by ldownes24, 18 Oct 2011.
  1. ldownes24
    ldownes24
    13 Oct 2011
    6
    Thanks Received:
    Country:
    Hi guys,
    I've recently ordered my new kitchen and have purchased the Henley tills from Topps; a ceramic floor tile.
    The area I intend to tile is 9m2 and consists of a solid, level and flat concrete base which is ajoined to floorboards in the dining room. The floorboards sit roughly 10mm below the level of the concrete.
    Should I purchase hardiebacker board and screw this firmly into the floorboards or remove the floorboards entirely and opt for another solution?
    Your comments are greatly appreciated.
    Thanks,
    Luke
  2. Sponsored Links
  3. Richard C
    Richard C
    26 Apr 2005
    10,625
    Thanks Received:
    1,001
    Country:
    You will obviously need to make up the height difference with something but how you do it depends on the construction of the suspended floor. It must be rigid with no perceivable flex or the tiles will fail, this is particularly important in high use/load areas such as a dinning room. What type of floor is it, proper timber floor boards or crappy T&G chipboard? Do you know what size/pitch/span the floor joists are?
    You also have another problem with two dissimilar floor types. You cannot tile continuously over them; the different floor types will expand & contract at different rates, you will need an expansion joint in the tiles where the two meet or it will crack.
  4. ldownes24
    ldownes24
    13 Oct 2011
    6
    Thanks Received:
    Country:
    Hi Richard C,
    The suspended floor has been in place for a good number of years and indeed are timber floor boards. The joists are roughly 400mm apart and span c3m.
    A brick wall used to be the partition between the dining room (floorboards) and kitchen (concrete floor) and thus the differing floor types and level. At present, a course of bricks just below the level of the floorboards.
    Thanks,
    Luke
  5. Richard C
    Richard C
    26 Apr 2005
    10,625
    Thanks Received:
    1,001
    Country:
    But what size are they?
    Don’t really understand this bit, can you explain please?
  6. ldownes24
    ldownes24
    13 Oct 2011
    6
    Thanks Received:
    Country:
    They are standard 2x4 joists.
    A course of bricks currently lays between the join (between the concrete floor and the boards) and descends into the foundations. This is where I've removed a partition wall and now want to tile over.
    Hope that helps.
  7. Richard C
    Richard C
    26 Apr 2005
    10,625
    Thanks Received:
    1,001
    Country:
    4 x 2 joists won’t be spanning 3m, are they also supported on intermediate dwarf brick walls below the floor? Maximum span for that size is around 1.8m but that would be insufficiently rigid for a tiled floor, it would be like trampoline.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
