Sorry - it's about sheds. But bear with me - I have done some searching, but have emerged confused, as you'd expect. Despite having wired in the odd ring main in the past I am well aware that nowadays I am not allowed to touch anything remotely electrical. But I'd still welcome your help in preparing something for a 'proper' sparky.
I am building a shed on (reinforced) decking which backs onto a garage. Shed and garage will be about 3 meters apart. The garage has power fed by a 32A MCB from the house CU via around 30m of SWA into an RCD protected CU which supplies hot tub, garage ring and lights. I am at the stage where the decking is all removed and I am shoring up the joists (the shed weighs a tonne because she picked it, because it looked "nice" - its not your usual £200 B&Q job...). Now is a very good time to bury some SWA between eventual shed and garage as it will be nicely concealed under the deck. I'll bury the SWA under the sand under the decking (still with me?) nice and deep as prescribed and punch it through the garage wall. The shed side will be fed up into it when I build it. Then I'll phone a man with pound signs for eyes to make it all work for me.
So silly questions:
1) Is it okay to run the shed from the CU in the garage? If not, there's no point burying this cable and I will deal with it by giving up.
2) I think the house is a PME earth which I guess has been extended to the garage (it's a newish house). Okay to extend again to the shed? If not, there's no point burying this cable and I will deal with it by giving up.
3) I have some 2.5 three core SWA cable (left over from a job I did for some friends - now sadly deceased - some years ago). Cable is in good 'nic. Shed will have two lights and two sockets ('tis but a modest shed). Is 2.5mm big enough d'you think? (Hope so, or I'll need a bigger drill bit - but I won't give up on this count...)
4) Under our new laws, am I allowed to wire in the ring and the lights in the shed from the CU, or will all the fires of hell raise up and consume me if I do this?
5) I am hoping to encase the shed CU in a water feature of some sort. Will this cause any problems? Okay - this is a joke.
Any help gladly received...
So silly questions:
