Hi
Complete newbie, so apols if this is a bit basic
Started tiling the bathroom and huge chunks of plaster fell off the outside wall, so started to prep for re-plastering. Noticed that the top section above the windows on this wall were 'leaning in' by a good measure, and the new tiles would therefore look odd (was previously wallpapered), so hacked this off to re-level and found a large wooden support beam running across the length of the wall.
To allow for the new tiles to stay in a rough vertical line, the lower section takes 12.5mm board OK, but the top (which leans in) has less than 6mm of depth available.
Given that this is an outside beam, sitting below the eaves and behind a soffit, how do I best plaster/prep this for tiling?
Appreciate any advice.
Cheers.
Cheers.
