Hi
Sorry another query about pressure drop in a combi boiler.
The boiler is a Biasi 28S combi. The pressure will drop only after the central heating has been on but if I re-fill and leave the heating off, the pressure does not fall. Incidentally even if the pressure has dropped right down to zero there is no loss of heating or hot water. Everything appears to work just fine still. Is that unusual ?
Have checked for leaks at all the radiators and can find none, they have all been bled and are all hot top and bottom. The boiler itself has been checked over by engineer who says it is in perfect working order.
Before I contemplate taking up floor boards to look for leaks I just wondered if the fact that the pressure does not drop when CH is off might point to the the problem not actually being due to a leak.
Would be grateful for any advice. Thanks
