pressure & flow question
27 Oct 2003
The mains supply to my cold water cistern is from 2x 15mm pipes which join at a T to feed a single 15mm pipe which then connects to the valve.
Am I right in thinking that having the 2 supplies to the T won't make any difference to flow because they end up going into a single length of 15mm piping, but if I replaced this section with a 22mm pipe it would make a difference?
No you are wrong.
The flow is subject to resistance in a thin pipe !
Tony
It sounds very odd having two pipes feeding in to a single one - are you sure you're looking at it the right way round (i.e. it isn't that one is a supply, one goes to your cistern and another feeds something else entirely (e.g. F+E tank)?
No you are wrong.
Tony
Hmm, ok.. point taken, how about if we assume frictionless pipes?
I guess what I'm really getting at is will adding a 22mm pipe after the junction actually double (22/15 squared) the flow in this situation?
Oh yeah, that makes more sense. :oops:
I was thrown by the fact that the join was about 6" from the tank, and after a clear 2m vertical run from 2 parallel pipes. Come to think of it I know exactly where the second supply goes.
