I have a sealed central heating and hot water system running off of a Alpha CDR18 boiler. It has been experiencing significant pressure loss (from ~1.0 bar down to 0.2 bar) after the heating has been on and the water cooled back to room temperature.
No water loss from the PRV (balloon put over the pipe) and the addition of 2 doses of sentinel leak sealer reduced the pressure loss for 2 days, but it has now returned. No signs of leaks in pipe work or from radiator valves.
When cold and the boiler off (with system pressure at 1.0 bar), pressure loss is negligible - 0.2 bar over 12 hours - surely it'd lose more if there was a leak in the pipe work?
Pressure loss of ~0.8 bar when boiler has been on for several hours (from 1.0 bar cold to 0.2 bar once cooled back down)
System pressure rises to 1.8 bar when boiler on and water hot. Holds this pressure for full time boiler is on and then falls to 0.2 bar when off and cooled.
Even if starting cold pressure is 0.2 bar, hot pressure still rises to 1.8 bar (according to the gauge) and the system works fine (rads piping etc).
Could this be a leak within the boiler heat exchanger (and loss of water out the condensate pipe)?
Only other options could be a leak in underfloor pipe work, or from the coil in the unvented cylinder?
Any advice appreciated. Want to rule out a boiler issue before I go looking for leaks. Anything I could try to diagnose etc.
Thanks!
Thanks!
