I've noted the FAQ page that states that a combi boiler will lose pressure at around 0.5Bar per 6 months and that if the pressure drops quicker than this I have a leak.
I also note that it may be through the Pressure Relief Valve or through the Automatic Air Vent.
I'm not sure when my pressure did start to drop, but it needs topping up about every 2 weeks.
About 6 weeks ago I removed a radiator and capped off the pipes and ran new pipework to another location, which at the moment is just capped off with isolation valves.
I have felt around all of the joints that I have changed and can't feel any water, whether pipes are cold or hot. Would such a small leak of pressure be noticed though through water discharge at these joints?
