Pressure reducing valve 3 Bar
18 Dec 2004
Hi Guys,
I have a Smart AVC cylinder and would like to a add a water softener.
From the blue poly stop cock there is a long stretch of 22mm copper where i would like to tap in to so I can add the softener. If i was to switch off the mains cold water and cut the pipe would I get any back flow from the cylinder or would the PRV prevent this and I should be okay to go ahead and do my connections?
Thanks!
PRV wont no, if it has a NRV fitted then you'll be ok but ideally you'll depressurise the centre cylinder/HW circuit. So it's turn off the heat source, isolate the cold feed and then open a hot tap. You will still have some water in the pipe so towels or a basin to catch it.
Though as it's an unvented hot water source then you really want a qualified engineer to do any work on it or its supply.
