Hopefully one of you can put my mind at rest. I live in a block of flats, and I have a very high water pressure rate which I guess is good. I have a pressure reduction valve fitted after my stop clock under the kitchen sink. It has a gauge on it with an apparently self moveable red line set at 3bar, and a black line which moves itself.
Now.. I have just started on refitting my kitchen, so have noticed this gauge when I have been turning the water on and off. My issue is that when i turn the mains on and have no taps running, the black line just keeps going up and up (like off the gauge into 8+ bar). Is this right, as I am concerned my pipes are going to blow up. When I run a tap, even very slightly, the black line drops to somewhere around the red line. So, is this the sign of a perfectly normal valve, or should that black line not be going off the gauge? As a precaution, I have closed the mains valve, and only turn it on when I need water.
Thanks in advance
Thanks in advance
