Hello everyone
I have a Centrestore unvented cylinder. Every now and again, the water pressure and flow rate at the taps drops right off.
I read the trouble shooting in the user manual and followed instructions to clean the filter in the pressure reducing valve. Each time I remove pressure reducing valve cartridge, the filter appears clear, but the small plastic half-sphere on the end of the cartridge is not attached to the cartridge.
Reseating the half-sphere and refitting the cartridge solves the problem and pressure is back to normal.
I'm assuming the issue is this half-sphere detaching itself from the cartridge and blocking the outlet pipe of the valve body. Is this correct? Am I right to believe that the half-sphere should be attached to the cartridge at all times.
Could I glue it in place to stop it from coming off again?
Burt
Burt
