Pressure relief valve on boiler should it be purged outside
3 Feb 2010
Glasgow
Hi i had British gas out doing the 1st service on my boiler for homecare, and the engineer said that new legislation stated that the pressure relief pipe could not be evacuated out the wall to the outside as it may burn a passer bye !!! so can anyone confirm where it is supposed to be housed ? also i was checking that the needle valves on the TVR's werent sticking so removed the regulator cover for temp control only to find they wont go back on, there is a little metal lug inside the regulator which stops it snapping back on to the brass totthed valve, the regulators are Danfloss, thanks in advance to all who reply.
You probably misunderstood him, the pipe must terminate outside either facing back into the wall or less than 300mm from the ground.
Before putting the thermostat back on the valve turn it up to full, it should go on easier then.
