what pressure an how long should i dry test my JG circuits for?
You'll do well to find a compressor that will pump up to 10 bar
Only an idiot tests with air. If you've bought one of those Monument dry test kits sold for the use of incompetent simpletons, then I'd suggest you take it back and ask for your money back; it is unfit for the purpose for which it was sold.
The instructions don't specify pressure or duration because it's f***** dangerous.
Out of interest, why is the airtester unfit for purpose, and why is it more dangerous than hydraulic testing?You'll do well to find a compressor that will pump up to 10 bar
Think the op is referring to JG (John Guest) placcy pipes for water purposes (possibly undefloor heating?)what pressure an how long should i dry test my JG circuits for?
JG?
If you mean gas then you would already know if you were registered as competent, if you are neither then no RGI should be telling you
